Intake backfire
Old Nov 17, 2015 | 02:59 AM
Grimace71's Avatar
Grimace71
Default Intake backfire
I recently changed my transmission and now having enteral backfireing does it have something to do with the crankshaft positioning sensor I removed and reinstalled during the re and really of the transmission thanks ken
Old Nov 17, 2015 | 10:36 AM
What are you driving?
Welcome to DF!
Old Nov 17, 2015 | 01:12 PM
Grimace71's Avatar
Grimace71
It's a 99 ram 1500 the transmission went all I did was put anewer one in it's out of a 02 but the transmission place said I shouldn't have any issues . Other than the park neutral switch which I plugged and just wired it direct now
Old Nov 17, 2015 | 03:06 PM
Didn't whack the distributor when you had the trans out did you? (may wanna have a look)
If the crank sensor was removed while the trans was doing it's out/in thing, it *should* be ok.
Old Nov 17, 2015 | 03:18 PM
Grimace71's Avatar
Grimace71
Ok thank you for your help I'll look into that .
Old Nov 17, 2015 | 05:12 PM
Any other issues, or, continuing this one for that matter, start thread in the second gen ram tech section. Lots of help to be had there.
Old Nov 17, 2015 | 11:24 PM
Grimace71's Avatar
Grimace71
I recently changed the transmission in my 99 1500 runs and idles fine but when driven I have a bad intake backfire . Would the crankshaft positioning sensor maybe have something to do with this I'm at a loss thanks ken
Old Nov 18, 2015 | 07:33 AM
Merging duplicate threads.
Old Nov 18, 2015 | 09:25 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
You maybe pinched the crank sensor harness pigtail coupling the trans back up. Seen it a million times. Done it a couple times.
