Hughes/edelbrock FI Airgap
Old Dec 2, 2015 | 07:20 AM
Spillage's Avatar
Spillage
Originally Posted by armynurse
I've got the hemifever tuner. Which setting (mine has three options) are you using that gets you the mpg increase?
Yes, Hemifever... I run premium and the third (hi octane) tune.
It has more get up and go, but if you keep your foot out of it and drive sedately, the mpg is good.
Old Dec 2, 2015 | 07:29 AM
If you plenum is really bad, you will actually have MORE low-end with the Air-Gap, than you do with your bad stock intake. Not as much as when it was new, but, more than you have now.
Old Dec 2, 2015 | 01:55 PM
Bwally1996's Avatar
Bwally1996
I might have got the truck with a bad plenum so who knows lmao
Old Dec 2, 2015 | 06:23 PM
It's a pretty standard failure. The truly rare birds are the ones that HAVEN'T failed.
Old Dec 2, 2015 | 06:25 PM
Bwally1996's Avatar
Bwally1996
You know, I wish they would have made it all one metal because if pull it tonight and weld it together lmao if I performance and a fix sounds good though
Old Dec 3, 2015 | 07:59 AM
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
It's an aluminum intake and a steel pan. Welding wouldn't be a good idea with that. You can try to weld an aluminum plate, but bolting up a new aluminum plate is probably best.
Old Dec 3, 2015 | 07:51 PM
Bwally1996's Avatar
Bwally1996
That's why I said "all one metal" lol. But nah if I'm pulling it apart I'm going to fix it forever
