Power steering feels weak
Old Nov 30, 2015 | 06:34 PM
Khris1994's Avatar
Khris1994
Default Power steering feels weak
The power steering has its moments usually when idling around turns where it feels like the power steering cuts out or gets super weak. It's been feeling weaker lately. Sound like the pump???
Old Nov 30, 2015 | 06:58 PM
Possibly. What does the fluid look like?
Old Nov 30, 2015 | 07:28 PM
Khris1994's Avatar
Khris1994
It looks clean and red. It's at least ten years old though. But with that said it doesn't smell burnt or look burnt
Old Nov 30, 2015 | 08:34 PM
Red? That's ATF, not power steering fluid..... It works, but, isn't really the correct fluid.
Old Nov 30, 2015 | 08:55 PM
Khris1994's Avatar
Khris1994
Well it's been like that since before it was bad. Maybe I can drain it and put new fluid in but i worry spending so much if that's not the issue. My car has atf instead and works the same as before.
Old Nov 30, 2015 | 09:02 PM
It's pretty much the same stuff, (hydraulic fluid.....) just different additive packages, more suited to the purpose. I have used it in cars/trucks as well, and it does indeed work just fine. I suspect it's a marketing thing.... but, some folks swear up and down that ATF doesn't make good P/S fluid..... I haven't really seen a good reason why, but then, I haven't looked that hard either.
Fluid probably isn't the issue. You could try flushing it, and see if it isn't just some bit o' dirt of grime clogging things up. It's an inexpensive attempt at least. Next step would be to check pressures......
Old Nov 30, 2015 | 10:18 PM
Khris1994's Avatar
Khris1994
I don't have tools to check pressure. Trucks got 33's and 3" lift with 150,000 miles registered.
Old Nov 30, 2015 | 10:29 PM
Has the system ever been opened?
Most of the big chain parts store will rent you the tools.
Old Dec 1, 2015 | 12:44 AM
Helgaiden's Avatar
Helgaiden
My brother's 92 w350 had a similar issue, but you could feel the steering wheel sort of shake and get weak as you turned the wheels. Turned out to be the pump. Got it rebuilt and he was good to go.
Old Dec 1, 2015 | 06:18 AM
Khris1994's Avatar
Khris1994
I don't think it's been open. It doesn't matter how far you turn the wheel the power steering feels the same all the way. I know the gear box leaks just a little. Hence the atf in the power steering
