Air in coolent system ?
Old Dec 5, 2015 | 11:37 AM
getdown78's Avatar
getdown78
Default Air in coolent system ?
What is the best way to purge all the air out of the coolent system on a 96 1500 ?
Old Dec 5, 2015 | 12:06 PM
Ramman18's Avatar
Ramman18
Do this when cold: Park it up hill or on a curb so the radiator cap is as high as possible. Remove cap, run truck until it warms up completely. Bubbles should work their way up and out.
Old Dec 5, 2015 | 03:03 PM
getdown78's Avatar
getdown78
so i went out and did that( got a few bubbles out of it ) but the top hose is hot, heater hoses are hot and the lower hose is cold ? Bad water pump maybe ?
Old Dec 5, 2015 | 04:03 PM
dbbd1's Avatar
dbbd1
Both heater hoses are hot, but the lower radiator hose is cold? How long did you run it?
Old Dec 5, 2015 | 06:07 PM
Lower radiator hose will be cooler than the rest. After all, that is where the cold (relatively speaking) coolant goes back into the engine.
Old Dec 5, 2015 | 11:42 PM
getdown78's Avatar
getdown78
it ran till after the t-stat opened and it was like 45 deg outside so not that cold ? heater hoses were hot but not too hot to hold on to !
Old Dec 6, 2015 | 12:43 AM
Dodgevity's Avatar
Dodgevity
What is your temp gauge saying? Is it overheating?
Old Dec 6, 2015 | 12:46 AM
getdown78's Avatar
getdown78
it only got just past 200 maybe 210 ? And the rad tank on pass side was cool too ? Just trying to get ideas so i can fix it !
Old Dec 6, 2015 | 10:57 AM
Moparite's Avatar
Moparite
How long did you run it? Take it on the highway for a drive. The higher rpm will work out any air left in it. The upper rad hose is hot so the t stat is opening, May still have some air left in the system. If you drill a small hole in the t stat this will allow the air out after you fill it.
Old Dec 6, 2015 | 04:45 PM
Ramman18's Avatar
Ramman18
This is exactly how it should work. Nothing is wrong.
