What Did He Do To My Differential ..
Old Dec 13, 2015 | 06:07 PM
Joe Wood's Avatar
Joe Wood
so he needs to put the same ratio back in, because I never tow a trailer, and I like the nice and easy low rpm top highway speed I had.
which parts does he need to replace?
I just got some new tires R601 265/70R16 which are slightly larger then my old ones.
Old Dec 14, 2015 | 07:42 AM
Find out exactly what happened, old ratio vs. new ratio. Take it from there.
Old Dec 17, 2015 | 02:33 PM
Joe Wood's Avatar
Joe Wood
Well, he said that they don't make the pinion and gear for my truck anymore,
could that be true, and if so could I get them somewhere else?
Old Dec 17, 2015 | 03:50 PM
Numerous companies make 3.55 gears for your truck. If he can't find them.... he isn't looking. Randy's Ring and Pinion probably has them on the shelf.
Old Dec 17, 2015 | 09:27 PM
Joe Wood's Avatar
Joe Wood
yeah, Randy's has them, I'll call them tomorrow!
matter of fact after I call them I'll check around locally, now that I know what the gear ratio should be. Any chance it could be some other ratio besides the 3.55 or is that a no brainer??
Really appreciate the advice :-)
Old Dec 17, 2015 | 10:19 PM
snowboundrmk's Avatar
snowboundrmk
Put your vin in here and it should tell you. Otherwise it should be on a sticker on your truck somewhere(mine was peeled off and is in the glovebox so don't know where)
http://dodge.custhelp.com/app/dodge/...VFU3BubQ%3D%3D
Old Dec 18, 2015 | 07:48 AM
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
Mine was actually attached to the under side of my hood. I've switched hoods though, the stick on my current hood peeled off...
Old Dec 18, 2015 | 09:26 AM
Joe Wood's Avatar
Joe Wood
right on Guys,
what numbers will I be looking for, 3.55 or something similar?
Old Dec 18, 2015 | 11:07 AM
snowboundrmk
3.21, 3.55, or 3.90
Old Dec 18, 2015 | 12:42 PM
BBartow's Avatar
BBartow
3.55 and 3.92 are the only options
