5.2L Mag or 5.9L Mag Option
Old Dec 22, 2015 | 03:05 PM
stewie01's Avatar
stewie01
Another way to free up some power is to get a SCT tune and remove the death flash...
Old Dec 22, 2015 | 04:24 PM
snowboundrmk's Avatar
snowboundrmk
I've got a 318 plate on mine. Depending on the year the weights were either on the converter or flexplate.
Old Dec 23, 2015 | 08:26 AM
Correct, I think it changed in 96, but, am not 100% on that.
Old Dec 23, 2015 | 11:37 AM
Moparite's Avatar
Moparite
Yeah 96 and later it was on the flex plate.
Old Dec 23, 2015 | 09:42 PM
Maximillio's Avatar
Maximillio
Besides the flex plate, is there anything else I need to watch for when doing the swap to the 5.9, or any tips for stuff I should look out for?
Old Dec 24, 2015 | 07:45 AM
Balancers are different too. Aside from that, the engines are pretty much identical. It will bolt right in, and hook right up. Of course, you will need to clue in the PCM to the additional cubes, the 5.2 PCM will tend to run it a bit lean. (till it gets into closed loop anyway.....)
Old Jan 5, 2016 | 07:00 PM
Maximillio's Avatar
Maximillio
Will the 5.2 PCM work properly with a 5.9, or would I need to pull a 5.9 PCM whenever I get the engine?
Old Jan 5, 2016 | 10:21 PM
The 5.2 pcm will run it, however.... (and you just KNEW that was coming..... ) it will tend to run lean when in open loop. Unfortunately, that includes running at large throttle openings...... which can be VERY bad. If you don't drive it hard, it will work ok...... but, I would recommend getting a tuner for it, and simply flash your current PCM to work right with the 5.9. (I think tuners are running around 400 or so these days, with a selection of tunes.) If you are going to stray from purely stock parts, cam, heads, etc, then you would need a custom tune, (which runs about 100 bucks or so more). If you just replace the 5.2 pcm, with a 5.9 pcm, you will need to have it flashed for your VIN, (which any decent shop should be able to do) otherwise, the air bag, and ABS systems will whine, and not work.
Edit: Not to mention, being an 01, your truck already has the 'death flash', which seriously compromises power and low end torque...... Tuner would fix THAT as well.
Old Jan 5, 2016 | 10:57 PM
Maximillio's Avatar
Maximillio
Well THIS one doesn't the engine that came out of it was a pretty well modified 5.2 which had a custom flash for it (otherwise woulda ran like junk with all its add on parts) so I guess I'm lucky, but its still not a 5.9 with bolt-on's :P So keeping this PCM you can simply tune it to work properly with a 5.9 with no adverse side-effects?
Old Jan 6, 2016 | 07:53 AM
Yep. One of the advantages of OBDII. Re-flash the PCM for your mods, from mild, to wild.
