Passenger seat removal
Old Jan 4, 2016 | 04:04 PM
shags's Avatar
shags
Default Passenger seat removal
I can't seem to get to the right rear second bolt, whats the trick?
Old Jan 4, 2016 | 04:09 PM
Is it just rusted up?
Old Jan 4, 2016 | 04:21 PM
shags's Avatar
shags
Not sure, at first I couldn't get it to slide forward enough to get to the back bolt, it feels like there is a catch in there somewhere not allowing me to slide it forward far enough to get to the second
Old Jan 4, 2016 | 07:08 PM
Warlock_III's Avatar
Warlock_III
You mean sliding it forward by the lever on the side? The center bolt or the outside?
Try reaching under the seat as you pull the lever and helping it. It may not be fully disengaging
Pass side
Old Jan 4, 2016 | 07:22 PM
shags's Avatar
shags
I guess its the center bolt, but its not in the center its towards the rear a few inches from the rear bolt
Old Jan 4, 2016 | 07:28 PM
Warlock_III
So its a 40//20/40 seat. I can't remember right now but is the seat belt through the hole you are talking about?
Old Jan 4, 2016 | 07:37 PM
shags's Avatar
shags
Here is how it was at first
Here is after I finally got it to move and was able to get the rear bolt out
And here is the bolt in question about 2 inches in front of the 1 I took out
I realize its a mess, I was just given this truck a few days ago and yes 40/20/40
Old Jan 4, 2016 | 07:57 PM
Warlock_III
Nice, so it was just corroded and needed some coaxing?
Old Jan 4, 2016 | 08:01 PM
shags's Avatar
shags
That bolt in the 3rd pic is still under the slide rail just out of reach
Old Jan 4, 2016 | 08:10 PM
Warlock_III
The release lever in the first picture with the wire on it SHOULD have another wire/cable in the empty hole across from the hole in front.
That wire should connect to the passenger's side rail (inner rail towards center) and pull out to release the seat. Look for the broken wire or hole it goes in and pull out on that part, then try to slide it alond the rail.
