Intermittent grinding/vibrating
Old Jan 5, 2016 | 07:27 PM
Joeyfish's Avatar
Joeyfish
Default Intermittent grinding/vibrating
I've been searching the web and this forum for any solutions, but I have failed to find what I'm looking for. Hence me being a new member and starting a new thread. I have a 1997 Ram 1500 with the 5.9 gas engine and auto tranny, 4x4. Whenever I drive (even if it's less than a mile) I usually hear (and feel) a random grinding/vibrating sound. It usually happens whenever I hit a bump and will last typically about 8 to 20 seconds or if I happen to hit another bump sometimes it stops. I checked all my u joints for play, and I'm in 2 wheel drive (although sometimes my 4 wheel drive won't work from I'm assuming the front axle actuator). I started towing my Jeep on a trailer recently and the grinding noise now lasts longer than usual. It's hard to tell where it comes from, but if I had to guess I'd say around the front or middle. A mechanic friend of mine rode in the truck and he said "That's certainly not good, sounds like a transfer case chain, but I'm not sure". But it's just a guess and I don't know how to check it. Any leads or questions?
Old Jan 5, 2016 | 09:16 PM
getdown78's Avatar
getdown78
Check the double joint on the rear of the front driveshaft ? Mine went out and tore the tcase in half !
Old Jan 5, 2016 | 10:10 PM
According to theory, in 2wd, the t-case chain isn't moving. You *might* here it slap once or twice over a hard bump, but, I rather doubt it.
Do you have the factory LSD by any chance? (limited slip differential)
Old Jan 5, 2016 | 10:41 PM
2bit's Avatar
2bit
Check the wheel bearings.
Old Jan 6, 2016 | 12:25 AM
Joeyfish's Avatar
Joeyfish
I checked all the joints, but I'll double check the double joint again to see if I've overlooked anything.
And I haven't thought of wheel bearings.. I'll check that too
And yes. I believe I have the LSD (although I only do one wheel burnouts)
Old Jan 6, 2016 | 07:52 AM
Verify you have the LSD. (get a build sheet, link in faq section) if you do, and it doesn't work.... time to have a look in there.
Old Jan 6, 2016 | 10:52 AM
dbbd1's Avatar
dbbd1
Any thoughts about it bring the transfer case output shaft? Personally, I have never heard the noises when the retainer shifts but maybe this is it?
Old Jan 6, 2016 | 03:02 PM
Would certainly be worth having a look.....
Old Jan 14, 2016 | 02:43 PM
Joeyfish's Avatar
Joeyfish
Alright, it's been a rainy week so I didn't have much time to check everything. I do have a LSD, I double checked all the joints and I jacked up the front end to wiggle whe wheels around to check for play in the wheel bearings. All of it seemed fine. The other day I was driving it and it started making the noise a lot longer than usual. I was on a dirt road at the time so I threw it in 4 hi while going about 35ish while it was making the noise and it stopped. Is it possible my transfer case just needs adjusted?
Old Jan 14, 2016 | 03:22 PM
UnregisteredUser's Avatar
UnregisteredUser
It seems to me more likely that it needs a transfer case saver installed before the case breaks violently apart.
It'd cost nothing but your time to get under there and have a look, but if it blows apart you'll be taking the BFH to the piggy bank.
