Where is the anti drainback valve?
Old Jan 9, 2016 | 08:20 AM
desker1%'s Avatar
desker1%
Default Where is the anti drainback valve?
What is the exact position? I'm installing a Hayden 679 independent of the inter-cooler and want to know; can I just cut the hoses and splice in while leaving the valve in tact?
Old Jan 9, 2016 | 09:46 AM
I assuming you are talking about the check valve in the trans cooler line? You will find it on the frame rail, passenger side, about 8"s or so from the lower radiator fitting for the trans cooler.
The valve is troublesome, in that it likes to clog up, and then you get zero flow thru the cooler, the trans overheats, and can quickly burn itself up, if you drive too far that way. Best bet is to eliminate the valve.
Old Jan 9, 2016 | 05:19 PM
dapepper9's Avatar
dapepper9
+1 to delete. Just put the truck in Neutral for 15-20 seconds or so before you start driving. Neutral, hold the brake, do all your HVAC radio adjustments, seat belt, drive and go.
Old Jan 9, 2016 | 08:40 PM
desker1%'s Avatar
desker1%
I've thought about the delete, some forums say yes some say no. My gut tells me yes, after all it's still a torque flight and I've driven my fair share of 727 and 727A behind a Chrystler B. I dig the convenience of not needing to charge the torque converter but whatever I never slam and go anyhow.
Old Jan 9, 2016 | 09:52 PM
dbbd1's Avatar
dbbd1
I made the compromise. I did the delete but went with an external filter, which has a check valve built into the filter itself.
Old Jan 9, 2016 | 09:56 PM
UnregisteredUser's Avatar
UnregisteredUser
You might consider installing a remote ATF filter -- you get your check valve back and keep the varnish and fines from ever reaching the cooler, let alone getting back to the transmission's internal filter.
EDIT: Looks like dbbd1 beat me to it. Two votes in favor!
Old Jan 10, 2016 | 10:53 AM
desker1%'s Avatar
desker1%
I need to get out and brap in the dirt today, but I've considered to external filter only to abandon the idea based on having a a RWD LT, then again Chrysler has a different definition of LT from others. I'm going to use my brap time time to delay my cooling system overhaul and order a bypass filter body. A remote filter body and general oil filter should work, right?
Old Jan 10, 2016 | 12:46 PM
UnregisteredUser
It should. Just don't put a Fram cartridge on it -- their quality control ain't what it needs to be.
Old Jan 10, 2016 | 01:19 PM
desker1%'s Avatar
desker1%
Baldwin or GTFO. Purolator is now making MOPAR and Supertech so I have quality control concerns there too.
Old Jan 10, 2016 | 02:41 PM
dapepper9's Avatar
dapepper9
Purolator makes good filters. Fram is junk. Wix is top of the line for regular oil filters.
