Brake line replacement
Old Jan 11, 2016 | 05:48 PM
shak's Avatar
shak
Just did the rear/intermediate brake lines recently on the '96 with rear ABS only.
If you want to go the pre-bent route here's the line parts I used from the front junction block... back to the rear wheel cylinders, but check for fitment on your specific model. Both steel and stainless steel are available...about $25 difference in the price.
Fine Lines WIN9602SS; Front to Rear Brake Line Set. $60
https://www.sstubes.com/win9602-3
Fine Lines WRA9401SS; Rear Axle Brake Line Kit; Stainless Steel $45
https://www.sstubes.com/wra9401
Dorman H38636 Hydraulic Brake Hose, Rear Center. $17
Amazon.com: Dorman H38636 Hydraulic Brake Hose: Automotive Amazon.com: Dorman H38636 Hydraulic Brake Hose: Automotive
Old Jan 11, 2016 | 05:51 PM
Lazzo's Avatar
Lazzo
Thank you for the links. I was looking into the pre bent lines and was all over the place. I will check fitment out and this will be the way I will go. Much appreciated!
Old Jan 12, 2016 | 10:17 AM
shak's Avatar
shak
Actually, for the rear, we replaced just about everything, including the shocks.
SS Tubes/Fine Lines sells there products a bit cheaper on Amazon than on their company website. Advance Auto had the rest. I did not have any problem with fittings matching, probably because everything, except the factory original front junction block, which worked with the SS/FL lines, was replaced with new parts.
Here's the complete parts list I used (minus fluid, and misc. brake line clips/brackets), again... check for fitment on your specific model...the build sheet helps with that.
Fine Lines WIN9602SS; Front to Rear Brake Line Set; Stainless Steel, pre bent with fittings.
Fine Lines WRA9401SS; Rear Axle Brake Line Kit (2 pieces); Stainless Steel, pre bent with fittings.
Centric Part # 123.67025. C-Tek Standard Brake Drums (Qty. 2)
ACDelco 17462R ACDelco 17462R
Durastop Riveted Rear Drum Brake Shoe Set. (Qty. 1)
ACDelco 18E394 Durastop Rear Drum Brake Wheel Cylinder Assemblies. (Qty 2)
ACDelco 18K553 Durastop Rear Drum Brake Spring Kit. (Qty. 1)
Monroe 37103 Sensa-Trac Light Truck Shock Absorbers (Qty. 2)
Total: $350.00 w/ tax and shipping.
Old Jan 12, 2016 | 11:30 AM
Lazzo's Avatar
Lazzo
Putting in the orders today. Though I think I may be mistaken on the ABS. Is there an easier way to tell? The master cylinder and ABS module under the hood maybe?
Old Jan 12, 2016 | 12:18 PM
Look at your front hubs. If you have wires going to them, you have 4wal.
Old Jan 13, 2016 | 07:21 AM
shak's Avatar
shak
Here's the link to obtain a "Build Sheet" for your truck. Have your VIN handy.
Very responsive...usually good at getting back to you in a day.
http://www.dodge.com/webselfservice/...mailpage.html?
My Build Sheet has this code/entry for ABS:
"BGJS Pwr Disc/Drum Rr Anti-Lock Brakes"
Your local dealer may have "instant?" online access to this info too.
