Running issue ?
My truck sometimes going up hill or under load acts like it is running out of gas or dieing but i push the gas pedal to the floor and does nothing until i let up on the pedal and then it builds power again and runs good from then on ? I thing it might be in the pcm but really don't know ? Any ideas ?
Yep it sure does ! You got any ideas ?
Your oxygen sensor is shot. Get one from the dealer if you want to be certain that it works the first time, or get Denso brand somewhere else. NTK's work but even a good one might leave you with a lumpy idle when the PCM first enters closed loop -- mine does, but is otherwise just fine. Venture off into other brands only if you really like doing things twice.
I hope the weather conditions in your part of the state aren't making driving as interesting as it has been here. Just about everyone I know has either spun out or whacked a critter in the last week.
Yesterday it was almost 50, and reasonably nice out. Dogs got me up at 3:00AM to go outside for a few, and it was still pretty nice out.... Got up around 8:00, only to see snow on the ground, the wind howling, and it is COLD!
Gotta love Michigan......
Trending Topics
Hanging a toy where the front sensor should be provides only two things: Poor part throttle performance and reduced fuel economy. You probably don't want that.
Be careful on that! Pretty much all of northwest Colorado was slick for most of the week, so it's been booming business for the body shop and wrecking yard and h3LL on the big game population.
Poisoning the world unnecessarily isn't a behavior I can condone, but with no converter and good sensors your engine will run just fine, all else being in good order. Without a cheat on the rear sensor it'll cause a converter efficiency fault, but you'd have had that for a long, long time if the cheat weren't already there.
