20x12's in 35's with a three inch body lift?
Old Jan 28, 2016 | 12:24 AM
valdez2017's Avatar
valdez2017
Default 20x12's in 35's with a three inch body lift?
i have a 1997 dodge ram 4x4 with a three inch body lift, how much rubbing would i have if i put on some 20x12's wrapped in 35's? or should i go with 33's? thanks
Old Jan 28, 2016 | 09:19 AM
1500? 2500?
On a 1500, 3" body lift is gonna be tight with 35's, and with the probably 3.55 gears, it's gonna be a dog..... 33's would be a better plan.
On a 2500, 3" lift will be fine with 35's, but, you still probably have the 3.55 gears, and yep, that'll make it a real dog off the line.
Welcome to DF!
Old Jan 29, 2016 | 12:26 AM
zildjian3707's Avatar
zildjian3707
with no suspension lift id stick with 33's but id pair 33s with some 4:10s. if your going for 35s get an actual lift and swap gears to 4:56. in my opinions i wouldnt go much above stock if your not gonna replace the gear ratio too. youll hate life if you dont.
