Brake light always on
Old Jan 28, 2016 | 07:24 AM
Lazzo's Avatar
Lazzo
Question Brake light always on
Hi,
So I bought a 00' 2500 for $600 and the brake light and ABS was constantly on. The truck has a ton of rust and the lines were leaking. Long story short I just had all the lines and master cylinder replaced. The lights were off and I parked the truck and engaged the parking brake. The light came on and I shut off the truck. This morning as I drive I release the brake and the light stays on. Any ideas on what it could be?
Side note:
Any good tutorials for removing front fenders?
Old Jan 28, 2016 | 07:29 AM
E-brake switch.
Front fenders should be pretty easy. Remove bolts, remove fender liner, probably the headlight, etc.
Old Jan 28, 2016 | 10:54 AM
dbbd1's Avatar
dbbd1
Yup, I agree.
Old Jan 28, 2016 | 07:00 PM
Lazzo's Avatar
Lazzo
Default Old problem
Thanks for the replies. I will check out what was mentioned. But now the brake light and ABS are constantly on, which is frustrating as everything was clear after the replacements
Old Jan 28, 2016 | 07:54 PM
dbbd1's Avatar
dbbd1
Oh, so you mean the brake indicator on the dash. Different animal all-together then.
Old Jan 28, 2016 | 10:28 PM
ABS system gets annoyed when the service brake system ain't workin' quite right. (and for a host of other reasons too.....)
Is your speedometer behaving itself?
Do you have 2, or 4 wheel ABS?
Old Jan 29, 2016 | 08:52 AM
Lazzo's Avatar
Lazzo
2 wheel ABS and the speedometer is working just fine. Maybe one of the sensors needs to be cleaned/replaced? Everything works fine and with the replacements I'm pretty much stumped.
Old Jan 29, 2016 | 08:59 AM
You only have one sensor, on the rear diff, and that also feeds the signal for the speedo. So, probably not a sensor.
Check the brake switch, and the e-brake switch.
Old Feb 9, 2016 | 07:54 PM
Jylee968's Avatar
Jylee968
It is the ABS unit under the Brake MC. I replace one from junk yard.
Old Feb 9, 2016 | 09:02 PM
fj5gtx's Avatar
fj5gtx
Default Front Fenders
Factory fenders are welded to the inner steel wheel well. Repops are usually just the outer, left up to the body guy to remove the inner from the old outer and weld it back together. Or they just buy both pieces new and weld them together. I bought used southern fenders, small amount of poly putty, and scuff/shoot paint.
Since the outer and inner are welded together, EVERYTHING connected to the inner needs to come off. Left side sux the worst.
