Quality Headlight Replacements??
So I've got a question that somewhat pertains to this. . .
My teucknis a 99 sport. I retrofitted projectors into a set of new single bulb housings. I need to rewire my current headlights so the low beams stay on with the highs. Is there a guide somewhere for this or will the heavy duty wire harness from lmc truck take care of this?
In order to make your single bulb system on what was originally a dual bulb system, you are going to have to move some wires around. The LMC harness won't help with that. I think you would be better off picking up some wire, relays, and such, and making your own.
Have a look at the wiring diagrams in the service manual. (get one here, if you don't have it already.) That'll show ya which wires ya need to play with.
You went to single bulb housings? If so, you don't want the highs and lows on at the same time, that will generate a lot of excess heat, and will DRAMATICALLY shorten bulb life.
I somewhat looked at the brite box and am wondering if that would do what I need?
i think proper hid's get power from relays activated by the factory wiring. it should sense power on low beam and activate the little flapper, then sense hi beam and open the flapper. but you shouldn't have to wire low/hi together. it should be plug and play on the ballast with your factory plugs. i'm going based on what i have read over the years, mostly morimoto stuff. but that seemed pretty standard with just about every kit out there.
by kit/standard i mean bulbs and ballast, what you stick the bulb in is a whole different ball game. what setup did you get?
here are the ones I found on eBay
http://www.ebay.com/itm/CHROME-HOUSI...ZV3mY2&vxp=mtr
let me know if these sound like a decent item PLEASE
That same basic style seems to be produced by the same factory for just about the entire aftermarket -- I paid $65 for mine, but have seen the same units being sold for as high as $289. I've yet to see a similar housing that was different in any way aside from the trim; black or chrome, rectangular or round marker lamp reflector, this or that shape filament guard.
I may be mistaken, but I believe that all of the single lamp housings throughout the second generation run were the same. Hopefully someone else will chime in to set me straight if I'm wrong about that.
"High/lo beam mod"? If you're referring to the hack that keeps the low beams on with the high, that's a thing I consider to be dangerous stupidity.
The headlight relay kit I'm speaking of is one that puts relay contacts (and nice fat wires) between the lamp filaments and the battery, and the relay coils in the original headlamp circuit. The quick and easy way to do it is to just score the prewired kit from LMC Truck.
UnregistereduUnregistereduser, is this the correct kit for my 1997 Ram 1500 with stock headlights?
Those may throw a blotchy pattern. The housings I'm running are the same style in a different color trim ("euro black"), but the filament guard (the reflective umbrella behind which the lamp resides) is of a different shape and might be responsible for the pattern irregularity. It looks to my untrained eye like it might be the filament guard causing it, but I don't know it with certainty.
those ones i posted the link to are not the ones i decided on. I thought about what you said, instead I ordered these
http://www.ebay.com/itm/401079173267...%3AMEBIDX%3AIT
After reading what you and HeyYou had to say about the wire harness replacement incorporating relays from LMC (by the way, thank you for posting the link to the harness at LMC!) I will be upgrading to that set up also.
UnregisteredUser,
If you don't mind, please let us know your impression of them once you've been behind 'em for a bit.
You'll like the difference the relays make. The improvement is pretty dramatic no matter what you've got out front, but with fresh housings and new premium lamps it's downright grin inducing.
