4x4 only works in low
Old Feb 5, 2016 | 10:13 PM
martinn16's Avatar
martinn16
Default 4x4 only works in low
My 4x4 for some reason will only engage in 4 Low not 4 High, the shifter does feel like it engages and the linkage is fine from what I can see underneath. any ideas?
Old Feb 5, 2016 | 10:20 PM
Put the t-case in 4 high, crawl under the truck, and try and rotate the front driveshaft. (engine off, trans in park.)
Old Feb 6, 2016 | 09:48 PM
Khris1994's Avatar
Khris1994
Make sure the tcase isn't slipping into neutral.
Old Mar 6, 2016 | 06:57 PM
martinn16's Avatar
martinn16
sorry for the delay, but when the t-case is in 4high I can not move the front driveshaft more than a quarter turn in each direction.
Old Mar 6, 2016 | 10:00 PM
Then the vacuum system is your problem. Check and see which port is getting vacuum at the cad. (on the front axle.) should be the inboard port. May just have a leak somewhere.
