diff between 99 1500 trans and 00 2500?
Old Feb 15, 2016 | 08:22 AM
fj5gtx's Avatar
fj5gtx
Default diff between 99 1500 trans and 00 2500?
I think I want a spare to rebuild. Would a donor from a 1999 1500 w/360 be a good candidate, or should i hold out for one from a '00 2500?
Old Feb 15, 2016 | 10:05 AM
According to theory, the electronics changed in 00. But, so far as I know, that is the ONLY difference. All the V-8 engines got the 46RE trans behind them. Doesn't matter what weight rating they were.
Old Feb 15, 2016 | 08:41 PM
zildjian3707's Avatar
zildjian3707
ya i don't think the tranny changed unless you had a V10 or cummins.
Old Feb 16, 2016 | 10:37 AM
Moparite's Avatar
Moparite
The bell housing was different on the diesel/V10. The pressure sensor changed in 2000. I would imagine it works the same just looks different.
Old Feb 17, 2016 | 01:01 PM
dapepper9's Avatar
dapepper9
96-97 have different governor sensor and neutral safety switch, 98-99 have the same governor sensor as 96-97. 00-01 moved the speed sensor to the rear diff. Not a problem, just put the sensor in place and you won't have an electrical plug for it.
Old Feb 17, 2016 | 09:29 PM
frankie_b_jr's Avatar
frankie_b_jr
Originally Posted by dapepper9
.... 98-01 moved the speed sensor to the rear diff....
Corrected
