1997 Dodge Ram 1500 4x4 popping noise
Old Feb 22, 2016 | 06:19 PM
Dodge_1997's Avatar
Dodge_1997
Default 1997 Dodge Ram 1500 4x4 popping noise
So I recently purchased a 1997 Dodge Ram 1500 4x4 drove her home (90 miles) no problems well the other day when leaving work I noticed a pop noise when I accelerate from a parking spot while turning right it's a single pop and now recently noticed a single pop every now and then from the front passenger side while going down my drive way around 10mph (gravel driveway) but it's not at all speeds only slow speed and when taking off turning right any ideas would be nice thank you.
Old Feb 22, 2016 | 06:39 PM
fj5gtx's Avatar
fj5gtx
check the u-joint at the end of the axle on that side.
Old Feb 22, 2016 | 06:51 PM
Dodge_1997's Avatar
Dodge_1997
Wouldn't that be a consistent clunk? Since it's always rotating? And what's the best way to check it?
Old Feb 23, 2016 | 06:26 PM
Dodge_1997's Avatar
Dodge_1997
I checked all u joints they're all tight any other ideas? Please and thank you
Old Feb 24, 2016 | 09:43 AM
Greaseable ball joints? Give 'em some.
Check calipers, make sure they move on their guides.
Front U-joints? Worn, or, dry and stiff?
Old Feb 24, 2016 | 01:41 PM
Dodge_1997's Avatar
Dodge_1997
I appreciate that info. My two upper ball joints are grease able the lowers aren't i will buy a grease gun and grease them and check the calipers tomorrow and report back what I find thanks again
Old Feb 27, 2016 | 08:23 AM
Dodge_1997's Avatar
Dodge_1997
I greased the upper ball joints and so far the noise is gone. So thanks hey you for the suggestions.
Old Feb 27, 2016 | 10:12 PM
2bit's Avatar
2bit
Cool! Thanks for letting us know what fixed the problem.
