rear tire in and out play 1996 ram
Old Mar 6, 2016 | 01:08 PM
j576's Avatar
j576
Possibly one of the 'wear shims' that goes behind the side gears. If you have a friend handy, have them push/pull the axle, and see if one of the side gears in the diff is really sloppy.
Looks like the passenger side is super sloppy ! And I noticed theres a clip missing from where the shims are behind the side gear. I'll provide pictures in a minute
Old Mar 6, 2016 | 01:12 PM
j576's Avatar
j576
There's the side gear (passenger side) I would say its got in and out play of about 1/2 to 3/4 of an inch. And also has some side to side play. I'm assuming that's what was making my rear tire wobble the last time I drove it
Old Mar 6, 2016 | 01:36 PM
Do you have the limited slip rear end???
In any event, you need to fix that before you drive it again.
Old Mar 6, 2016 | 01:45 PM
j576's Avatar
j576
I honestly have no idea, how do I identify that ?
Old Mar 6, 2016 | 01:58 PM
Do you see plates between the side gears, and the carrier housing?
Old Mar 6, 2016 | 02:01 PM
j576's Avatar
j576
Give me a minute I'll got take way better photos
Old Mar 6, 2016 | 02:37 PM
j576's Avatar
j576
hopefully that will help
Old Mar 6, 2016 | 02:40 PM
j576's Avatar
j576
the clip in the last picture is what i think is missing on the passenger side
Old Mar 6, 2016 | 03:49 PM
I do believe that is indeed a LSD. Pick up the rebuild kit for it, and go thru it. (don't have to pull the carrier) Should be golden.
Old Mar 6, 2016 | 04:07 PM
j576's Avatar
j576
any suggestions of where to order from ??
