rear tire in and out play 1996 ram
Hahaha more then an 1/8th, I'm going to start having to pay you as my mechanical advisor !
I have a paypal account......
rear axles are held in by C clips. Gotta pull the cover off the diff to see 'em. A little bit of play is normal. If you think it's excessive, need to have a look inside, and see what's goin' on. So long as the axle doesn't pull out completely though, it usually ok.
Seriously?!?! Dang, I thought I got rid of c-clips when I got rid of the jeep. I did get an eliminator kit for that vehicle.
It's one of the poorly designed things on the 9.25. No c clip eliminators for it to my knowledge. ??? I would check it sooner then later, If it is excessive the clip may brake/fall off and the axle shaft will come out of the rear while driving. Not fun!
Trending Topics
I will be pulling off the diff cover this weekend and have a look and see what's going on ! Will update with what I find ! Thanks guys
Possibly one of the 'wear shims' that goes behind the side gears. If you have a friend handy, have them push/pull the axle, and see if one of the side gears in the diff is really sloppy.
