rear locker
Ok you guy's will like this one I have a 2001 dodge ram I live in Colorado but mu truck is only 2 wheel drive or should I say 1 wheel drive. Has anybody tried to put a locker in the one and what is a good one to try?
I haven't tried to put a locker in yet. I plan to put in 4.10 gears and a locker to make it a posi-trac. A friend of mine is a dodge mechanic and told me he could do it for 300 bucks. I don't know if it is easy, but I'm gonna try to barter with him later. I'll let yall know how it turns out. btw..I have a 2001 Dodge Ram reg cab 2wd w/5.9...It ought to run pretty stout with 4.10 gears and posi-trac.
-Tyler
-Tyler
If you put a locker in, make sure it's a TRUE locker like a Detroit or an ARB. Don't get one of those lock-right locker kits. They are worthless. Also...if you do a lot of towing, DO NOT get an automatic locker (like the Detroit). If you tow, you would want a selectable locker like the ARB, which is pnuematic.
ORIGINAL: The Burning Rom
ORIGINAL: steve00ram360
I wouldnt do a locker in Colorado... unless you can lock it out when you need to. get a posi instead... reason... snow.
Ice is another story though. It would be kind of tricky...being that it's only a 2wd.
I never had any troubles on it with the Chevy though. Too bad that truck rusted in half. [:'(]As far as availability, I guess ARB doesn't make one for the 9.25. It's available for just about every other axle though. Just one more reason to upgrade to a Dana 60 Hi-Clear.
The Detroit auto locking differential would be your only option if you have the 9.25.
Trending Topics
I live in Colorado, and have an Auburn limited slip (mines a 4x4 though). I find it to be very good in the snow and ice, but also very tolerable the rest of the year when the roads are dry. If you off-road a lot in the summer, the locker would still be a good way to go though.
If you can't find a locker, you might look for a factory limited slip at a wrecking yard. When I purchased my '01 ram 2500HD QB LB 5.9L 4.10 Diff I also ordered it with the limited slip and 4-wheel ABS. Though I live in SoCal I drive home to Spokane, WA at the holidays (do not like flying, allergies to perfume/cologne). It is not uncommon to run in snow and/or ice from the OR/CA border and back, about 800 miles one way. Have never had any problems with treaction and that is with the stock Michelin tires. Just an idea that I thought I would throw out there if you can't find what you need elsewhere.
