injectors
Old Mar 6, 2016 | 02:35 PM
zildjian3707's Avatar
zildjian3707
Default injectors
thinking about upgrading my injectors. Good idea or bad idea? If so which ones should i get. Anyone notice a diff in power?
Old Mar 6, 2016 | 03:50 PM
The only improvement you will see, if any, is improved performance if you currently have injectors that aren't doing their job properly.
Old Mar 6, 2016 | 10:27 PM
adukart's Avatar
adukart
Injectors aren't worth the headache, especially if you aren't custom tuning for heads/cam/stroker. The only ones I have heard that offer minimal (if any) improvement with a stock motor are the 2000 on up red injectors that the magnums switched too. So if you could find a wreck 2000+ ram that would be the way to go, but honestly these intakes/heads were designed around the factory (imho crap spray pattern) injectors so that's why the improvements are so minimal.
Old Mar 8, 2016 | 10:12 AM
dapepper9's Avatar
dapepper9
The reds use the same injection pattern. The difference is simply due to government regulations for the USCAR connector. If you're not boosting or stroking it, it's a waste of time and an easy to mess your truck up. Simply because I was curious and like to learn for myself instead of take others word on things I even tried it. Stock are 22lb/hr at 43.5psi and I tried some that were 23.6lb/hr at 43.5psi and only about 25cc more flow. Stock is about 24lbs at our 49psi and the ones I tried were about 25-25.5 at 49psi. Idle did not change, did not smell gas and didn't seem like it ran too awful rich or nothing. Go to take off from a stop and lots of tq to GET moving but once it was moving it was lacking. The PCM can't trim it back and set the A/F ratios quick enough with incorrect fuel tables/trims based off the stockers. WOT it screamed but cruising was gutless unless I went WOT. One of those things you'd need a custom tune for and why go through that pain in the *** when a stock displacement 360 naturally aspirated the stock will handle anything you can throw at it? Just adds another factor to complicate things and fail.
