speedometer issue 94 Dodge 1500
Old Mar 13, 2016 | 06:49 PM
bpdoxey's Avatar
bpdoxey
Default speedometer issue 94 Dodge 1500
94 dodge 1500 4x4 5.9L. The problem is the speedometer only works sometimes. I have replaced the speed sensor on the transfer case. I also noticed that my abs and parking brake light was on so I changed the abs speed sensor on the rear differential. with all that I still cant get it to work. Need help please.
Old Mar 13, 2016 | 08:26 PM
Moparite's Avatar
Moparite
Does your truck go into overdrive? If the pcm didn't see a reading from the speed sensor it wouldn't go into od. It may be the gauge or wiring. The abs/brake lights both on means there is a fault in the abs somewhere. Disconnect the battery that should clear the abs code if it was the sensor on the rear.
Old Mar 13, 2016 | 09:06 PM
bpdoxey's Avatar
bpdoxey
Truck does go into overdrive
Old Mar 13, 2016 | 09:47 PM
If it isn't bouncing in an out of O/D while the speedometer is screwing up, the problem is somewhere between the PCM, and cluster. (probably between the sensor, and the cluster, not sure which gets it first.)
Old Mar 13, 2016 | 09:49 PM
bpdoxey's Avatar
bpdoxey
Ok I'm gonna pull the cluster off tommorow and check wires. I hope I figure it out. It's really starting to **** me off
Old Apr 6, 2016 | 08:26 PM
bpdoxey's Avatar
bpdoxey
O/d was working fine. Then I got stuck. Put the truck in 4L and sounded like something was going to snap. Loud metal popping noise. I git pulled out, then my o/d hasn't worked since. Still no speedometer either
Old Apr 7, 2016 | 08:46 AM
Fix the speedometer, and O/D will more than likely start working again as well.
