cam questions
Old Mar 14, 2016 | 08:37 PM
mccart's Avatar
mccart
Default cam questions
Building a 408 stroker motor for my pulling truck. I'm wanting to run a solid cam but I'm not really wanting to spend what they want to make a custom solid roller cam. Anybody on here run a flat tappet cam in a magnum block? Or does anybody know if a LA block has the same motor mounts as a magnum?
This is in a 97 truck. I already have it swapped to a carb.
Old Mar 15, 2016 | 08:09 AM
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
I've seen online where magnum 360s have been carbed and installed in old mopar cars. Might want to check out magnumswap.com
Old Mar 15, 2016 | 11:49 AM
dapepper9's Avatar
dapepper9
LA shares same motor mounts.
Read this if you haven't:
http://www.hotrod.com/how-to/engine/...-mopar-engine/
Also you can use LA headers with Magnum gaskets if exhaust was a question at all.
Old Mar 16, 2016 | 07:39 PM
Adobedude's Avatar
Adobedude
Get a solid roller cam and solid roller lifters from MRL, that's what I'm running in my Eddy Headed 408.
