Slight misfire
Old Mar 22, 2016 | 08:31 AM
Pull the throttle body, and look at the back of the intake. That's where oil usually pools. (and a gasket is like 2 bucks.....)
Old Mar 26, 2016 | 06:46 PM
RamFever360's Avatar
RamFever360
I pulled the throttle body and noticed just a hair of oil but its coming from where the pcv comes into the plenum. Definitly not a blown plenum because both ends are clean as a whistle.
Old Mar 27, 2016 | 10:36 AM
Could try using an oscilloscope, see if coil output is consistent. One member found a failing crank sensor would give him weak spark on several cylinders.
Old Mar 27, 2016 | 10:53 AM
dbbd1's Avatar
dbbd1
Where are you at? Because I do have a o-scope.
Old Mar 27, 2016 | 11:07 AM
RamFever360
New york
Old Mar 27, 2016 | 11:08 AM
RamFever360
Crank sensor was one thing someone else suggested.
