47RE inconsistent shifts
I did a solenoid service kit on my '99 Ram 2500 which fixed the issue of having to let off the gas to shift from 1st to 2nd, but I've noticed that the shifting doesn't always want to be the same as far as the RPM range is concerned. It can be an early shift that kicks a little harder, a later shift that is softer, a later shift that is harder........
EDIT: non of the shifts are abnormally harsh, late or early. the temperature doesn't seem to make any difference on shifting behavior either
The truck went a while without being fixed and drove with the lift out of the throttle to shift deal going on and I don't know how long the previous owner drove it like this.
All the linkage is ajdusted and operating normal as far as I can tell. I'm wondering if something in the transmission might have gotten kinda sticky from not shifting correctly for so long and if I could try some additive in it to maybe free things up. This is my thought on what may be the problem, but I'm no transmission expert. I've also heard a lot of mixed reviews on additives....especially putting them in a Dodge.
Any thoughts? I don't know if the shifting like this may lead to bigger problems down the road or is it just something I can live with, without being a big deal on the transmission.
You stated it was down for awhile,Most often the fluid gets moister in it.A full service is probable needed . a good tranny shop or dealer for inspection.Fluid is suppost to be changed every 28000-30000 miles along with band adjustment and filter.Just a thought.It willcost a few dollars,but if you use the truck it will be worth the cost.
Thanks for the replies. I will look over the adjustments again, but everything looked O.K. when I did the kit. I did adjust the bands ( the rear one is fun) and put new filter that came with the kit. You said they can get moisture in them and have a shop look at it. Do you mean maybe have them do a flush on it? I've heard before that sometimes those aren't good too. Too much new of fluid at once or something( if that is not true, I'd like to know the truth about it.). I guess its better then moister though. It may be a good idea to have them at least hook it up and see what everything is reading.
