Ext. cab door fit std cab?
Old Mar 27, 2016 | 10:35 PM
Deadlymopar408's Avatar
Deadlymopar408
Default Ext. cab door fit std cab?
Im currently restoring my 94 dodge ram 1500 and of coarse the lovely salt of the northwoods has destroyed the drivers side door. My question is will a ext. cab door fit a standard cab??
Old Mar 28, 2016 | 04:20 AM
stewie01's Avatar
stewie01
I think some will but, not doors from extended cabs that have the rear opening door.
Old Mar 28, 2016 | 08:56 AM
Stewie is correct. If the cab has the rear doors, the fronts will not fit on cabs that do not have 'em.
Old Mar 28, 2016 | 09:06 AM
TSU_Delta_Chi's Avatar
TSU_Delta_Chi
Yep. Club cab = yes, quad cab = no.
Old Apr 7, 2022 | 08:40 AM
Markpolson@netscape.com's Avatar
Default Club cab door for standard cab.
I took a door off a club cab and put it on a standard cab in the salvage yard. The door panel trim on the bottom corner had to be modified to get the door to close. I had to cut out about a three inch square on the bottom corner.
Old Apr 7, 2022 | 10:15 PM
2bit's Avatar
2bit
My extended cab has a standard cab door on the passenger side. It fits but doesn't look right on the bottom corner. I don't think an extended cab door would fit on a standard cab because it has a square corner instead of round.
Old Apr 8, 2022 | 02:32 AM
You are correct. That is why I had to cut out the interior plastic trim on the bottom corner.
