Clearance lights
Old Apr 4, 2016 | 05:22 PM
David Clauder's Avatar
David Clauder
Default Clearance lights
I have installed clearance lights and I want to wire them to my headlight switch but I don't know which wire or wires to splice to. Can y'all help?
Old Apr 4, 2016 | 06:59 PM
dbbd1's Avatar
dbbd1
What year is your truck?
Old Apr 4, 2016 | 10:33 PM
David Clauder
It's a 2001. I've got it rigged to an old switch right now so it will work but I want it permanently attached to the main wire that powers the headlights as soon as u flip em on
Old Apr 4, 2016 | 11:21 PM
UnregisteredUser's Avatar
UnregisteredUser
Headlight switch connector C1-1 (Connector 1, pin 1), black/yellow. That'll illuminate your clearance lamps with the parking lights and headlights. You may have to increase the rating of Fuse F in the Power Distribution Center to avoid nuisance failure of that fuse.
If you don't already have it, grab the factory service manual and take a peek at section 8W.
Old Apr 5, 2016 | 12:03 AM
David Clauder
How do I increase the fuse rating? Put a higher fuse in its place?
Old Apr 5, 2016 | 03:33 AM
UnregisteredUser
Yep. You probably won't need it, but if that fuse (fuse F in the PDC) blows every now and then for no apparent reason, stuffing a 25A fuse in there should eliminate that nuisance failure. But then remember to add no additional loads to that circuit in the future because you don't want to make campfires between your knees and the front bumper.
Old Apr 5, 2016 | 02:42 PM
Moparite's Avatar
Moparite
Add led bulbs to it also, That will keep the amp draw down. Are you aware of the heating up of the switch terminals? This was a problem on the 2500 and 3500's due to the amount of amps threw them.
Old Apr 5, 2016 | 07:41 PM
dbbd1's Avatar
dbbd1
Originally Posted by UnregisteredUser
Yep. You probably won't need it, but if that fuse (fuse F in the PDC) blows every now and then for no apparent reason, stuffing a 25A fuse in there.
I hope that is sarcasm. I'm surprised that you would advocate that. Like moparite said, switch to LEDs and you won't have a problem. Or even just in the clearance lights.
Old Apr 5, 2016 | 07:55 PM
David Clauder
Clearance lights and headlights r standard bulbs...
Old Apr 5, 2016 | 08:03 PM
Double Oh Dodge's Avatar
Double Oh Dodge
That's what Moparrite meant, get LED clearance lights, or get the LED type replacement bulbs which would be the brighter lumen option.
