Need help bad 2001 Dodge Ram 1500 power windows and blower motor
Old Apr 10, 2016 | 06:15 PM
dbbd1's Avatar
dbbd1
Originally Posted by fordsblue73
Thanks guys found it. The black and orange wire had a bad connection.
Just as an FYI, was that under the hood or under the dash?
Old Apr 10, 2016 | 06:30 PM
fordsblue73's Avatar
fordsblue73
The loose wire was in the steering column where it connects to the ignition switch. The 30amp. Fuse is under the hood in the power distribution block.
Old Apr 10, 2016 | 06:41 PM
dbbd1's Avatar
dbbd1
Great, thanks. Glad you got it fixed.
Old Apr 10, 2016 | 06:45 PM
Do you have tilt-wheel by any chance? I found out (the hard way) that if my steering is all the way up, a selection of stuff stops working...... Seems the wiring harness may be just a tad too short....
Old Apr 10, 2016 | 10:12 PM
fordsblue73
Yes I have tilt-wheel. And I did see that. I cut the factory ties and moved them up. I was putting some led off road lights on two days before this and had the wheel all the way up. I think that's when things got loose.
Old Apr 10, 2016 | 10:25 PM
fordsblue73
Thumbs up
http://api.viglink.com/api/click?for...E%3C%2Ffont%3E here is a service manual that's great
Old Apr 11, 2016 | 10:04 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
I have been studying the wiring diagram and the black and orange wire from the ignition switch supplies the power to all the thing I am having trouble with. So Iam going to try and trace this wire to the fuse box.
Or a melted ignition switch connector.....
Old Mar 26, 2019 | 12:50 PM
Kevin Moree's Avatar
Kevin Moree
Default blowewr motor and windows dont work
Thanks guys found it. The black and orange wire had a bad connection. Tighting the connection and got power on it. All so the 30 amp fuse that feeds that wire was ever so slightly blowed. Could barely see it. When you took it out to checked continuity it would give false reading loose inside fuse. Again thanks for y'alls help.
please help,,,,where exactly is black orANGE WIRE, GREAT IF YOU COULD SEND PHOTO OF LOCATION 65 YOLD WITH POOR VISION AND SAUSAGE FINGERS
