Truck starts and runs for 2-3 minutes then dies
Old Apr 18, 2016 | 07:04 PM
kussy99's Avatar
kussy99
Default Truck starts and runs for 2-3 minutes then dies
1999 Dodge RAM 1500 5.9L sport. Can not figure out what the the problem is replaced the distributor cap and rotor, spark plugs (old ones had a lot o carbon build up), ignition coil, and fuel pump. Truck has compression, and fuel pressure. Has no spark after it dies, let it sit for awhile and it will start up and die again.
Old Apr 18, 2016 | 07:05 PM
Does the fuel pump run while cranking, when you have the no-spark condition?
Old Apr 18, 2016 | 07:26 PM
kussy99's Avatar
kussy99
It turns on when you cylce the key, it does run run because I have good fuel pressure.
Old Apr 18, 2016 | 07:36 PM
That indicates the PCM isn't seeing the engine turning once it dies. Possible crank sensor?
Old Apr 18, 2016 | 08:33 PM
kussy99's Avatar
kussy99
That is what I'm getting ready to replace
Old Apr 18, 2016 | 09:57 PM
It's a pain, but, doable.
Get your new sensor from the dealer. The aftermarket fellers don't always play nice with the PCM.
Old Apr 18, 2016 | 10:13 PM
kussy99's Avatar
kussy99
I got one from advanced. Installed it. It has spark now. But still just
crankes.it tries but won't turn over
Old Apr 18, 2016 | 10:19 PM
kussy99's Avatar
kussy99
Old Apr 19, 2016 | 09:44 AM
Are you getting GOOD spark? On all cylinders? Does it even attempt to fire? Backfire? Anything at all?
Old Apr 19, 2016 | 02:02 PM
kussy99's Avatar
kussy99
Has spark. It kind of tries. Back fired when it died. Ran for 20- 30 minutes this morning after it sat all night. Replaced that censor last night.
