Second Gen blend door
Old Apr 26, 2016 | 08:03 AM
Sassaman15's Avatar
Sassaman15
Default Second Gen blend door
My blend door is shot, and I am replacing it this weekend. Does anyone know of any tips,on how to do it. I really don't want to remove whole dash. Also not fully sure where it is located at. I've read about it being under the dash and somewhat easily accessible with a stubby Phillips head, or a 90 degree one. Any info would be greatly appreciated. This is my first blend door job ever, well anything HVAC at that.
Old Apr 26, 2016 | 08:38 AM
What year is your truck, and what leads you to the conclusion the door is shot?
Old Apr 26, 2016 | 08:48 AM
Sassaman15's Avatar
Sassaman15
It's a 99 1500 with the 5.9. When I bought the truck from a dealer they said they ordered the part for it which was the blend door, and when I first go it the HVAC would only blow cold air, then I hit a big pothole and now it only blows heat, so I suspected with the blend door broken, when I hit the pothole... It switched the door from AC to heat.
Old Apr 26, 2016 | 09:48 AM
dbbd1's Avatar
dbbd1
One word...
Heater treater.
Old Apr 26, 2016 | 10:11 AM
Does the 99 use the little motor under heater box, or is it still cable controlled??
@OP: take a look at the heater box, under the dash, just to the passenger side of the trans tunnel. Is there a little box there bolted to the bottom of the heater box??
Old Apr 26, 2016 | 10:42 AM
dbbd1's Avatar
dbbd1
Motor. Mines a '99 too.
Old Apr 26, 2016 | 10:54 AM
Ah, then I would almost bet that the heater treater will solve the issue, without having to completely disassemble the interior of the truck.
Old Apr 26, 2016 | 11:12 AM
Ramman18's Avatar
Ramman18
Door is fine. Get the heater treater kit! It's a bit tight contorting upside down with teeny screws but no dash removal!
http://www.heatertreater.net/magento...ram-95-02.html
