96 dodge ram starting problems.
Old May 30, 2016 | 07:02 PM
  #31
Originally Posted by Friar Tuck
How long can a PCM hold its breath?
About ten to 15 minutes.
Old May 30, 2016 | 11:44 PM
  #32
j576's Avatar
j576
Originally Posted by dbbd1
I'm concerned about the low voltage on the gauge. Check that with an actual voltmeter. Or did it correct itself when you tweaked the idle?
It went back to normal after it starts idling properly !
Old May 30, 2016 | 11:47 PM
  #33
j576's Avatar
j576
Hhhmmm.... Not sure if that will get base values for sensors or not...... Cheifly, IAC, and TPS.
Tossed in the old IAC and had the battery unhooked for an hour or so, I guess time will tell if my situation changes ! Haha the brand of aftermarket IAC I got was "bwd"
Old May 30, 2016 | 11:51 PM
  #34
j576's Avatar
j576
Also I've noticed a difference in the way it starts in the cold and in the heat.. Morning time when its colder out the truck won't idle stalls out, it starts fine when I press the gas a little, and then after the motor warms up a bit it runs fine!
After work when its been sitting in the sun all day I go to start it and just cranks ! No fire then I give a little gas and it starts up and idles fine ??
I guess the motor retains enought heat that it can idle right away ?
Old May 31, 2016 | 09:11 AM
  #35
See if behavior stays the same with the 'new' IAC....... take it from there.
Old Jun 1, 2016 | 10:10 AM
  #36
j576's Avatar
j576
HEYYOU to the rescue again, so far so good with the old IAC seems to start fine every time now. A little more time will confirm 100% but I'm guess bad IAC out of the box or like you said it adjust to slowly !! Crappy parts haha
Old Jun 1, 2016 | 10:24 AM
  #37
Awesome. Lets hope it STAYS fixed.
