Knock in the driver's side floorboard 1999 ram 1500
Old May 3, 2016 | 10:32 PM
embrey.brandon's Avatar
embrey.brandon
Default Knock in the driver's side floorboard 1999 ram 1500
When driving there is a knock in the driver's side floorboard. You can feel it in your feet and hear it from inside vehicle when moving, does it in 4x4 and 2x4. It can not be heard outside the vehicle. Nothing appears to be loose, shook the drive shaft and nothing. The only thing in that area is the transfer case. I need help. It is in a 1999 dodge ram 1500 4x4.
Old May 3, 2016 | 11:42 PM
69_XS29L's Avatar
69_XS29L
Control arm bushings or cab mounts. There may have been a factory bulletin for the cab mounts. Good luck, Mike
Old May 4, 2016 | 01:08 AM
master tech's Avatar
master tech
Site Moderator & Tech
If I remember correctly. There was a problem with the bushing on the shifter linkage. That would cause a knocking type sound.
Old May 4, 2016 | 08:12 AM
Had any work done on the front of the truck lately?
Old May 4, 2016 | 12:22 PM
Moparite's Avatar
Moparite
Track bar loose?
Old May 5, 2016 | 12:59 AM
master tech
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 21-012-00, DATED
SEPT. 15, 2000, WHICH SHOULD BE REMOVED FROM YOUR FILES AND NOTED IN
THE 200 TECHNICAL SERVICE BULLETIN MANUAL (PUBLICATION NO.
81-170-00001). THIS IS A COMPLETE REVISION AND NO ASTERISKS HAVE BEEN
USED TO HIGHLIGHT REVISIONS.
SUBJECT:
Tranmission Shifter Linkage Rattle
OVERVIEW:
This bulletin involves installing a spring on the transmission linkage
MODELS:
2000 - 2001 (BR/BE) Ram Truck
SYMPTOM/CONDITION:
A rattling or knocking sound may be present at the driver side floor pan area when the
engine is idling.
DIAGNOSIS:
With the engine at idle, listen for a rattling or knocking sound coming from the driver side
floor pan area. If the sound can be heard or a if a vibration can be felt in the floor pan,
perform the Repair Procedure.
PARTS REQUIRED:
Qty. Part No. Description
1 05101832AA Spring
AR 04318063 Grease
REPAIR PROCEDURE:
1. Place the transmission in park.
2. Raise the vehicle on a hoist.
3. Pry the gear shift rod vertical link adjuster block from the torque shaft lever(Fig. 1).
Inspect the plastic grommet. If any damage is present, replace the grommet
Old May 5, 2016 | 06:35 AM
ramsportrocks's Avatar
ramsportrocks
check your transmission mount too
