performance valve body for 46RE
Old May 9, 2016 | 07:28 AM
ramsportrocks's Avatar
ramsportrocks
Originally Posted by Moparite
Same here! It used to be the first weekend in June if i remember correctly. Then they moved it to late May and then now in August. That show will never be what it once was. If you plan on towing put in a trans cooler! Heat will destroy a trans. If you have the trailer package it already has one.
yes event always seemed to fall on may 31/june 1 or first full weekend in June they then moved it to mid may and weather most times was worse.. NOW usually last weekend in august or damn near it.. again powers that be never listen I think weekend after Carlisle would have been perfect to try and get the vendors to stay in the area.. oh well they know better than the actual MOPAR owners
now back to the truck
YES it already has the towing package and that BIG BEAUTIFUL OIL COOLER!!.. looking like Daytona is where im going to end up so im looking at 1k trip one way and probably 2 trips down and back... all highway fortunately but still I don't trust these transmissions even though it was rebuilt because all I got was a receipt showing the rebuild and cost so I don't know what went in to it BUT I can tell it isn't performance or towing..
Old May 9, 2016 | 07:31 AM
ramsportrocks
WOW site messing up, tried to edit above post and it wouldn't let me
forgot to add, found a local place to install a shift kit but man $400 plus cost of kit
is that about the going rate now??? haven't had a shift kit installed in 20 years
Old May 9, 2016 | 08:15 AM
That's outrageous. You can do it yourself in a couple hours. MonteC recommended the Sonax Sure Cure kit, and the Trans Go shift kit. Yes, there is some overlap between the two, but, you get firmer, crisper shifts, can check fluid level in park, and a few other goodies.
Old May 10, 2016 | 07:24 AM
ramsportrocks
4 herniated/2 fused discs in cervical, 3 herniated in thoracic and 2 blown out and needing fusion in lumbar means I cant do it myself.. this is what happens when a case of paper 55lbs falls on your head, you end up in bad shape physically and 1" shorter... LOLOL could have been worse could have ended up paralyzed..
read all through MonteCs thread and everything he recommended I would have done BUT at $400 just for a shift kit install not sure I would even want to ask about the sure cure, this is why I was leaning towards a performance built throttle body and just having it installed
Old May 10, 2016 | 09:13 AM
Yeah, I guess you ain't gonna be crawling around under there..... Ooops.
Check a couple other shops, you should be able to find a better price.....
Old May 11, 2016 | 07:38 AM
ramsportrocks
yeah I have to look around some more, these guys are super reputable in this area though and they are the ones that rebuilt my rear last fall..
