Need help with engine selection!
Old May 16, 2016 | 09:45 PM
That's my understanding of the situation.
Old May 16, 2016 | 10:59 PM
Maximillio's Avatar
Maximillio
Awesome, do you know what lead to a HP/TQ increase in the later model years? Would a 01 engine be better than a tune corrected 94?
Old May 17, 2016 | 01:04 AM
UnregisteredUser's Avatar
UnregisteredUser
The removal of the divider that halves the plenum is responsible for the power increase. Just hacking the thing out of an older manifold will get you the same increase.
Old May 17, 2016 | 02:43 AM
Maximillio's Avatar
Maximillio
That's it? Wow!
Is there any other reason I should consider getting a newer year engine than the 94? Or will everything else be the same? Any other noteworthy improvements?
Old May 17, 2016 | 03:52 AM
UnregisteredUser
The electronics changed, but the engine itself didn't change any.
Old May 17, 2016 | 08:24 AM
Newer engine might be more likely to have fewer miles?
Old May 17, 2016 | 06:25 PM
Maximillio's Avatar
Maximillio
Will there be any missing sensor spots on the older motor in the 2001 truck? Did they add in extra plugs that wont be present on the 94 engine?
Old May 17, 2016 | 06:37 PM
Actually, you pretty much break even. Only one coolant temp sensor, (two wire) and two O2 sensors, on the 98 and up trucks.
Old May 17, 2016 | 06:41 PM
Maximillio's Avatar
Maximillio
Will these being there or not effect operation at all?
Old May 17, 2016 | 07:42 PM
The second temp sensor was for the gauge in the dash, on the newer trucks, the way the gauges work is totally different, so, that one won't matter. The post-cat O2, on the other hand, NEEDS to be hooked up, else the PCM will whine about it.
