Power door locks not working
Old Jun 7, 2016 | 03:48 PM
TheCrazyRam's Avatar
TheCrazyRam
Default Power door locks not working
I just bought a 2001 Dodge Ram 1500 and the locks work fine but the power door locks are not working at all. I'm thinking it might be a fuse but I'm not sure what fuse to replace or where it would be. Any help would be appreciated. Thanks!
Old Jun 7, 2016 | 05:13 PM
TSU_Delta_Chi's Avatar
TSU_Delta_Chi
First, you will want to go here and get your service manual for your year truck. Page 653 should get you to the Diagnosing and Testing section of the Power Door Lock System. Start from there and go down the list. In my case, I had a bad ground (I wound up removing the factory grounding setup and did my own) and the main power wire had a short in it. I had to run fresh wire from the driver side door to my passenger side door. (The power runs from the driver door switch assembly to the passenger side assembly and then to the CTM). It took me a solid two weeks to work through all the steps doing it part time in the evenings, but it was worth it to have my power locks back!
Old Jun 8, 2016 | 03:53 AM
Friar Tuck's Avatar
Friar Tuck
Fuse 13, 10 amp, in junction block in dash by driver door.
Old Jun 24, 2024 | 10:47 AM
GP42's Avatar
GP42
Default 2013 Ram 2500
When I either lock from the fob or driver/passenger door, only the driver door and tailgate will lock. When unlocking all doors and tailgate works as designed. Anyone had this happen and what did you find?
Old Jun 24, 2024 | 12:44 PM
You want to be in the fourth Gen ram section.
