Truck stalling
Old Jun 10, 2016 | 08:10 AM
jsmith1969's Avatar
jsmith1969
Default Truck stalling
Ok decided to take the Ram for a drive last night after work and drove normal for around 5 minutes then stalled at a light. It restarted after a couple minutes and then did it again a few miles down the road and eventually restarted and got her home. I was able to replicate it after about 5 minutes sitting in the driveway.
No codes, can hear fuel prime when trying to restart, coil ohmed out good. I'm thinking crank position sensor or is there something else I should check before I start throwing parts at her?
At work so won't be able to do anything until afterwork but was going to pick up ckps on way home unless yall think I should try something else first.
Old Jun 10, 2016 | 08:27 AM
How's the plenum and catalytic converter? Last tune up?
Old Jun 10, 2016 | 08:30 AM
jsmith1969's Avatar
jsmith1969
Fixed plenum plate last summer, Cat is around 4 months old, about 6 months since since tuneup
Old Jun 10, 2016 | 01:28 PM
jsmith1969's Avatar
jsmith1969
Ok called around on ckps, $100 at dealer, $50 Autozone. I know it's worth it to use Mopar parts on iac and tps(ask me how I know lol) , does the ckps need to to be Mopar as well?
Old Jun 10, 2016 | 04:31 PM
UnregisteredUser's Avatar
UnregisteredUser
Yes! It's even more important there than in the IAC and TPS.
Old Jun 10, 2016 | 04:51 PM
jsmith1969's Avatar
jsmith1969
Noted.
Also with how hard it is to get to I'd really hate to have to do it again because of trying to save $50
Old Jun 10, 2016 | 06:13 PM
Pain in the keester. You can see it, OR, you can touch it, but, not both at the same time. Some folks find it easier to go in from above, others get it from underneath.... I went in from on top, and yep, it was a pain. many small cuts and abrasions before I was done......
Old Jun 11, 2016 | 12:12 AM
odzmaker's Avatar
odzmaker
this is next on my list. crank position sensor
Old Jun 11, 2016 | 08:13 AM
jsmith1969's Avatar
jsmith1969
Picked up the Mopar part last night on way home but had to meet the inlaws for dinner so will be installing it today after work. Hopefully it doesn't cost me to much blood getting it in
Old Jun 11, 2016 | 05:33 PM
jsmith1969's Avatar
jsmith1969
Ok got the ckps installed and took truck for a drive and seems to have fixed the stalling. If I have time tomorrow after church I'll take it for a longer drive to make sure
