96 ram 1500 outside temperature reading
Old Jun 13, 2016 | 12:00 PM
schmidtp's Avatar
schmidtp
Could always run to the bone yard to see if another Ram has one
Old Jun 14, 2016 | 02:17 AM
Friar Tuck's Avatar
Friar Tuck
Thumbs up
OVERHEAD CONSOLE
When the ignition switch is in the RUN or START
position, circuit F12 from fuse 11, a 10 amp, in the
fuse block supplies power to the overhead console.
When the headlamps or parking lamps are ON, circuits
L7 and E2 provide voltage to the overhead console.
Circuit E2 from fuse 13, a 5 amp, in the fuse
block powers the illumination lamps in the overhead
console. Circuit E l from the headlamp switch feeds
fuse 13 and circuit E2.
Circuit Z l l provides ground for the compass.
Old Jun 14, 2016 | 02:23 AM
Friar Tuck's Avatar
Friar Tuck
Lightbulb
C33S (WITH HIGH-LINE CLUSTER)
CAV CIRCUIT FUNCTION
1 E2 220R FUSED PANEL LAMPS DIMMER SWITCH SIGNAL
2 L7 20BK/YL** PARK LAMP SWITCH OUTPUT
2 L7 18BK/YL* PARK LAMP SWITCH OUTPUT
3 - -
4 G32 22BK/LB SENSOR GROUND
5 G31 22VT/LG AMBIENT TEMPERATURE SENSOR SIGNAL
6 M2 22YL COURTESY LAMPS DRIVER
7 F12 22DB/WT FUSED IGNITION SWITCH OUTPUT (START/RUN)
8 -
9 Z l l 20BK/WT GROUND
10 - -
11 Z4 18BK GROUND
12 Ml 18PK FUSED B(+>
13 Ml 18PK FUSED B( + )
* WITH CLEARANCE AND I . D . LAMPS
* * WITH OVERHEAD CONSOLE ONLY
