What is all INTERCHANGeABLE through the 2nd gen RAMS
Old Dec 22, 2024 | 09:46 AM
FixinTime's Avatar
FixinTime
Default Power steering gear box
I have a co-worker who has a gear box he took off his 96 ext cab. Can I put it in my 00 single cab?
Old Dec 22, 2024 | 10:06 AM
Yep. Should bolt right in. If you are going from auto to manual though, you will need other parts as well. They also need to be the same drive line. (2 or 4 wheel drive.)
Old Dec 22, 2024 | 10:52 AM
FixinTime's Avatar
FixinTime
Perfect. Thank you.
He's just going to give it to me, so I wanted to be sure.
Old Dec 22, 2024 | 11:29 AM
Originally Posted by FixinTime
Perfect. Thank you.
Give it to you? Ok, that works.
Old Dec 22, 2024 | 01:32 PM
AtomicDog's Avatar
AtomicDog
Smile
Perfect. Thank you.
What a holiday present!
Old Feb 4, 2025 | 05:43 PM
Midnight's Avatar
Midnight
Default Interchangeable
94-95 pretty much anything. 96-97, pretty much anything, 98-01, again, pretty much anything...... Now, between the three groupings, pretty much nothing in the way of electronics as related to the engine.
What years are the trucks you are looking at?
Welcome to DF!
hey could u please help me out as well I’m trying to find out if a computer brain outta a 97 dodge ram is interchangeable wit one outta a 99 both the 5.2l please help
And it says no bus……..
Old Feb 4, 2025 | 05:46 PM
Nope. 98 or 99 should work though. I am not sure when the trans temp sensor changed though, it *might* have been 99, but, I *think* it was 2000.... Keep in mind, no matter what you get, it will have to be flashed to the correct VIN, or ABS and SRS won't work. (and will whine about it.)
