Transmission stuck in first
Old Jul 17, 2016 | 10:13 AM
dbbd1's Avatar
dbbd1
^yes, you should.
Old Jul 17, 2016 | 10:20 AM
tot64's Avatar
tot64
Where can I get one then? Cause I looked at the auto part stores and they don't show one
Old Jul 17, 2016 | 10:38 AM
tot64's Avatar
tot64
It looks like the only way I can get that gasket is by ordering a $65 paper and rubber seal kit from autozone. $65 for one gasket? There has to be another way
Old Jul 17, 2016 | 10:44 AM
If there was one there originally, probably a good idea to put it back.
Old Jul 17, 2016 | 11:03 AM
dbbd1's Avatar
dbbd1
Is the old one trashed? If not, just re-use it.
Old Jul 17, 2016 | 12:16 PM
tot64's Avatar
tot64
The old one wasn't in real good shape, but yea I reused it. Seems like everything works for the moment! Onto the next thing that needs fixed!!!
Old Jul 17, 2016 | 12:28 PM
dbbd1's Avatar
dbbd1
Next time (or if that one fails), you could always just make a new one out of bulk gasket material. Double-check the material thicknesses though.
Old Jul 18, 2016 | 10:09 AM
tot64's Avatar
tot64
Thanks, I will keep that in mind. How will I know if that one fails?
Old Jul 18, 2016 | 10:10 AM
dbbd1's Avatar
dbbd1
I could not tell specific symptoms, but if your trans starts acting up, I would check that first.
