Need help
Old Jul 21, 2016 | 05:39 PM
biglou165's Avatar
biglou165
Default Need help
1995 dodge 1500 5.9 liter, truck was running fine and then one day driving home. It started surging and hesitating, no power. I have replaced the following parts, idle air valve, thorttle position sensor, crank sensor. It idles fine, until I decide to shift it and in reverse or drive it stalls out, no codes or check engine light. Need help.
Old Jul 21, 2016 | 07:41 PM
Moparite's Avatar
Moparite
Did you clean out the throttle body where the iac goes? It gets clogged up with carbon. You may want to check what kind of fuel pressure you have also to rule that out.
Old Jul 22, 2016 | 07:43 AM
How's the plenum?
Old Jul 22, 2016 | 08:30 PM
lwiuff's Avatar
lwiuff
I'm with Moparite - my 5.2l did the same thing. Had it towed to the stealership. They cleaned out the TB and I was out of there an hour later for $125.
Old Jul 23, 2016 | 10:17 PM
biglou165's Avatar
biglou165
Thorttle body was removed and all sensors removed, soaked in cleaner and all sensors replaced.
Old Jul 23, 2016 | 10:18 PM
biglou165's Avatar
biglou165
Originally Posted by jkeaton
How's the plenum?
Plenum gasket was replaced with hardware two months ago.
Old Jul 23, 2016 | 10:20 PM
biglou165's Avatar
biglou165
Fuel pressure is at spec.
Old Jul 24, 2016 | 07:19 AM
ramsportrocks's Avatar
ramsportrocks
Clogged Cat? see what kind of flow you have at the exhaust tip
Old Jul 25, 2016 | 02:20 PM
biglou165's Avatar
biglou165
Cat was replaced and the flow is good.
Old Jul 25, 2016 | 06:34 PM
What brand IAC valve? Some of the aftermarket fellers simply do not react as fast as the PCM expects, so, you get interesting issues.
How old are the cap/rotor/wires/plugs?
Run a spark checker on it? (can just use an old spark plug on the coil wire, See what the spark looks like, and, is it consistent.)
