Seized engine 2001 ram laramie
Old Jul 30, 2016 | 07:46 PM
angrysmileyface's Avatar
angrysmileyface
Default Seized engine 2001 ram laramie
Ok so the 5.2lengine in a friends 01 ram is totally locked up. Don't know the reason. In the mean time picked up a used replacement. Currently pulling stuff out of the truck and I'm down to the lower engine mounts, rear bell housing bolts and tc bolts. I realize since I'm unable to turn the engine the side effect will be to take the torque converter wit the engine which most people don't recommend. So a few questions. What's the best way to undo the 3 upper bell housing bolts as well as get the torque converter free
Old Jul 30, 2016 | 08:00 PM
44dakota's Avatar
44dakota
In all honesty you might be better off pulling the who engine and transmission out in one shot, if its 4wd you'll probably have to unbolt the transfer case, plus it will make life so much easier when it come time to reinstall as well..
Old Jul 31, 2016 | 12:01 AM
Moparite's Avatar
Moparite
Drop the pan and see if you can remove the rods from the crank. Since it's trash if you can't get them off just cut the connecting rod so you can turn the crank.
Old Jul 31, 2016 | 08:36 PM
angrysmileyface
Wound up pulling the engine with the tqc attached. Once out of the engine bay wound up having enough space between flex plate and motor to use a long handled genius wrench with 0deg offset to undo the 4 bolts holding it in place. Next chore will be dropping another one in and lining stuff up.
Old Aug 1, 2016 | 07:04 PM
Change the front seal on the trans before reinstalling the t/c.... chances are it got tweaked when the engine was pulled. Its easy right now, put the engine back in, and THEN discover the leak, you will not be happy.
Old Aug 1, 2016 | 09:07 PM
angrysmileyface
Is there any trick to replacing that seal or just freeze it over night and lube it with some atf+4
Old Aug 1, 2016 | 09:26 PM
Having the right driver for it helps, but, isn't absolutely required. Leaving it in the freezer overnight will definitely help on the install. Smearing a little grease on the t/c snout that goes in there isn't a bad idea either.
Old Aug 2, 2016 | 04:57 PM
angrysmileyface
Does anyone know the seal number for a transmission with the 787 converter?
Old Aug 3, 2016 | 08:02 PM
angrysmileyface
Or is it the same for all autos 94-01
Old Aug 3, 2016 | 09:06 PM
There are parts manuals available in the FAQ section here. One of the sticky threads.
