Hey guys. Have a problem on my 95 2500. Headlights randomly flicker on and off while driving. I've replaced the alternator, both headlights, the headlight switch on the dash and on the steering column. Still does it. Any ideas?
Reason: Needs to go to 2nd Gen
You replaced the headlight switch but what about the connector? The 2500's and 3500's have more lights to run than a 1500. This subject was talked about in another thread. There was a update for the issue with the 3500's but they seemed to forget about the 2500's. This is what mine(2500) looked like.
could be that COMMON lose wire issue in the multi switch
if you have a tilt wheel, try moving the wheel up and down
when it happens and see if they come back on
