No start think it's bad fuse pannel
Old Aug 4, 2016 | 12:13 PM
douglassunseri's Avatar
douglassunseri
See if you are getting power on pin 30 of the starter relay. If not, check for burnt fuses.
No reading on 30 just the other two I may be doing it wrong
Old Aug 4, 2016 | 12:18 PM
Friar Tuck's Avatar
Friar Tuck
There are two 40 amp fuses in the circuit for the starting system.
Fuse 3 feeds the ignition switch, and energizes the starter relay.
Fuse 2 feeds thru the starter relay to the starter solenoid.
Old Aug 4, 2016 | 12:20 PM
douglassunseri
I found a burnt 40amp ignition run fuse burnt so I'm gonna go get that and see what happens
Old Aug 4, 2016 | 12:21 PM
Friar Tuck's Avatar
Friar Tuck
Lightbulb
What HeyYou said. That's fuse 2.
Old Aug 4, 2016 | 12:22 PM
douglassunseri
Awesome so maybe that's the problem. I'll keep you posted when I get the fuse
Old Aug 4, 2016 | 12:24 PM
Friar Tuck's Avatar
Friar Tuck
We got this! Still worried about the relay. That's fuse 3, and that ckt is only uses to energize the starter relay.
Old Aug 4, 2016 | 12:26 PM
douglassunseri
I look at that one it was green with a clear top and it looked like it was perfect I also have the starter relay fuse with me
Old Aug 4, 2016 | 12:37 PM
Friar Tuck's Avatar
Friar Tuck
Talking
Relay pin 30 is connected to fuse 2, so if that fuse is good, 30 should have power.
85 and 86 are the relay coil.
86 gets power from the ignition switch.
85 gets ground from the park/neutral position switch.
When the relay is energized, pin 30 is connected to pin 87, which feeds the starter solenoid.
Old Aug 4, 2016 | 12:46 PM
Friar Tuck's Avatar
Friar Tuck
HeyYou, u still there? By we. I mean u and i.
Old Aug 4, 2016 | 12:59 PM
I am in and out today..... Kinda 'drive-by' posting.
Pin 30 should be hot at all times. Red lead goes in there, black lead goes to a good ground. (which can be found from damn near anything metal....) Meter should be on 20 volt DC scale.
