Fluid check
Old Aug 9, 2016 | 07:57 PM
jordons2's Avatar
jordons2
Default Fluid check
Is it better to check the fluid in park or in neutral. When I check the fluid in park the level is fine when I check it in neutral is low. I've read both ways. Is good. Any help would be great. Thanks
Old Aug 9, 2016 | 08:18 PM
dbbd1's Avatar
dbbd1
Neutral. That's what the book says.
Unless you (or someone) has upgraded the trans, fluid only flows in neutral, not park.
Old Aug 9, 2016 | 08:59 PM
jordons2's Avatar
jordons2
It was a quart low in neutral is that enough to effect performance
Old Aug 10, 2016 | 09:01 AM
Yup. Runs hotter too.
