How to remove dash, replace heater core and AC evaporator core
Old Aug 29, 2016 | 07:06 PM
Moparite's Avatar
Moparite
You may want to add who you got the heater core from and what style. I replaced mine the first time with an oe style from napa and it lasted a little over a year. Then i went with the aluminum one and it's been in ever since.
Old Aug 30, 2016 | 01:54 AM
beeker's Avatar
beeker
Added to top. That's a good tidbit that could save a member some serious downtime, thanks for reminding me. Sorry you had to find out the hard way!
Also added about the cores with less vertical runner tubes causing less heat transfer.
HeyYou can you please recopy to DIY again or copy the new section at the top, thank you.
Old Aug 30, 2016 | 08:55 AM
Done.
Old Nov 29, 2016 | 10:11 PM
1997DodgeRam's Avatar
1997DodgeRam
Great work thanks for all the pics. I am going to be digging in soon or buying a better coat and gloves for this winter. Now I just have to decide how much I want to do. AC has been good last few summers so I hate to mess with it, tempted to go just go parts store core with swivel lines so I can leave AC alone and still get heat.
Anyone have experience with any of the following?
spectra heater core from Amazon $39.98? cheapest but 12 month warrantee
Napa $55
spectra from autozone 58.99 more expensive than amazon, same brand but lifetime warrantee... cue Tommy Boy quote about guarantees
pro source autozone 58.99
Old Nov 30, 2016 | 12:39 AM
beeker's Avatar
beeker
Napa $55
Thanks, I got mine from Oreilly, not sure what brand. The spectra had some recent bad reviews leaking from a crimp. I wouldn't take the chance on it. Since it's winter I'd probably skip AC core and get the heat going quickly, try to find a good flexible tube model. Maybe someone has a good suggestion.
Get yourself some window and door foam from the hardware store to wrap around the sides, top and bottom of the new core to seal it up and prevent air and debris from passing around the side of the core. The old core has foam but the new one most likely won't have any. It will be too old to reuse.
Old Nov 30, 2016 | 09:42 AM
Brian in Tucson's Avatar
Brian in Tucson
Napa $55
The problem with buying stuff like radiators, cooling stuff, & heater cores on the internet is if they are defective or damaged in transit, you are on the hook 'til they can send a replacement. You pay your money, you take your chances. (I had this happen on a Dakota radiator.) Buy one from a local source, you're going to pay more but if it's wrong you can go back and get the correct or undamaged one.
OTOH, saving 20 or 30 bucks has a lot to recommend shopping the 'net sources. Money is tight for me. So I tend to look closely at Amazon (free shipping) and Rockauto (reasonable shipping, no tax, & a 5% discount.) Rockauto has one for $27.99 base price with a lifetime warranty. (P/N TYC 96009)
Of course, the biggest cost will be the time and mess involved in switching it out if it is bad. And inside quality is something you have to take on trust--no way to check. And most cores are checked at the factory for leaks (all Spectras are.)
