Steering strangeness
Old Sep 9, 2016 | 03:47 PM
Nate_rs's Avatar
Nate_rs
Originally Posted by Ramman18
Well, you're missing the sway bar, end links, and stabilizer. I would start there.
All the TREs look good.
Yeah I opted to remove those about 15,000 miles back. I didn't notice any difference in handling or steering so I'm not going to put them back on now
Old Sep 9, 2016 | 06:58 PM
Sway bar just controls body roll in corners. It shouldn't make any difference to what he is seeing......
Stabilizer wouldn't matter either. Mine has been toast as long as I have own the truck.... Still drives ok. (but, I do need shocks.....)
Old Sep 10, 2016 | 11:29 AM
Ramman18's Avatar
Ramman18
Well, my truck must be special because I could tell an improvement by changing just my end links, and adding my stabilizer to my HD steering last week. I'm not saying they are essential, just that they do make a difference.
If your truck is still moving, it must be how its mounted to the frame, meaning the track bar ends. I see it has an adjustment in the middle? Are those jam nuts alien tight?
Old Sep 10, 2016 | 07:18 PM
Nate_rs's Avatar
Nate_rs
Yeah I'm thinking about putting in a nice stabilizer at some point. That'll be after I get this sorted though.
Yeah they're pretty damn tight, both ends are torqued to spec and it is very solid in there.
I want to try popping the old pitman arm back on just to see if it makes any difference but the new one is so damn ballsy that the puller doesn't fit over it....
Any idea how to get that off?
Old Sep 10, 2016 | 11:09 PM
Two big hammers. (I use a pair of three pound single-jacks. (big *** hammers)) Hold one hammer against one side of the collar around the sector shaft (where the arm mounts to the steering box), and SMACK the other side with the other hammer. Two or three good hits, and it should drop right off.
Old Sep 11, 2016 | 08:57 AM
Moparite's Avatar
Moparite
big *** hammers
BFH's!
