Break Lights and rear Blinkers
Old Sep 5, 2016 | 02:45 PM
Thecanman's Avatar
Thecanman
Unhappy Break Lights and rear Blinkers
Howdy, I have a 1997 Dodge RAM 2500 with the V10 that I just purchaced I have replaced the water pump front U-Joints rotars calapiars pads and such. But for some reason The rear Break lights will not work Nor the rear turn indiactor lights. I have checked the bulbs and the fuses that I could find. The third break light above the back cab window does work however. tried the hazzards front work fine but nothing in the back. Any suggestions would be welcome> thanks!
Old Sep 5, 2016 | 02:47 PM
Thecanman's Avatar
Thecanman
I should mention that the front blinkers work just fine.
Old Sep 5, 2016 | 03:23 PM
Check where the rear harness plugs into the rest of the harness, make sure it IS plugged in, is clean, and tight. If you have a trailer harness, have a look where it hits the main harness.... they have been known to cause some troubles.....
