Mystery oil consumption and smoking
Old Aug 29, 2016 | 11:18 PM
adukart's Avatar
adukart
Default Mystery oil consumption and smoking
So its a 98 5.9l with the hughes intake, new pcv valve, and has started to smoke under high vacuum. I can't see it smoke when I'm decelerating under normal condition but a friend that was following me said he can. However if I put it in second gear at 60-65mph and totally let out of the throttle I have a james bond style smoke screen. Now at WOT nothing, its only under high vacuum when you're slowing down. So has anyone else had this issue? A friend suggested valve stem seals. I'm kinda lost. Oh it idles smooth as butter and has no hint of a missfire. Popped the radiator cap and no bubbling so no indication of a head or head gasket problem. Truck is approaching 161k.
Old Aug 30, 2016 | 05:56 AM
Moparite's Avatar
Moparite
Disconnect the the pvc valve going to the intake and see if that is where the oil is being sucked in.
Old Aug 30, 2016 | 08:53 AM
Valve seals sounds like a pretty good candidate..... Also, if your PCV is aftermarket, may wanna go to the dealer and get one.... They actually have the correct flow rate.
Old Aug 30, 2016 | 05:40 PM
adukart's Avatar
adukart
I have a mopar pcv thats only 3 months old in there. I'm thinking about pulling the valve covers and having someone crank the motor to see what happens. I pulled at the spark plugs and they look clean yet.
Old Aug 30, 2016 | 05:44 PM
Do you have the air-gap intake? Or the hughes plate?
Might consider doing a compression check.
Old Aug 30, 2016 | 11:38 PM
adukart's Avatar
adukart
I have the air-gap. I am considering do the compression check as well. Doesn't seem low on power like low compression but you never know til you do it.
Old Aug 31, 2016 | 08:44 AM
Well, its not a plenum problem then.
Do the compression test, and see what your numbers look like. Take it from there.
Old Sep 1, 2016 | 11:26 AM
William Littig's Avatar
William Littig
I would look into a bottle of at-205 before I thought about a costly repair like that. All it is is a reseal. It recondition the valve seals. It worked on mine
Old Sep 2, 2016 | 11:10 PM
adukart's Avatar
adukart
I have a bottle of AT-205 that I used on the power steering in my old grand prix. I think I should just do the seals and some 1.7 rockers as well, I may keep this truck for awhile unless I can find an off-road edition.............
Old Sep 4, 2016 | 10:23 PM
adukart's Avatar
adukart
So in a strange turn of events my truck quit smoking? I haven't done anything to it except put on 300 miles in 10 days. Now I'm totally lost, thinking about a compression test tomorrow.
