whining noise between my transmission and engine
Old Sep 5, 2016 | 05:51 PM
David Clauder's Avatar
David Clauder
Default whining noise between my transmission and engine
I have an 01 ram 4x4 manual trans and recently it's been making a winning noise from what UK thought was a loose drive belt but I changed it and it still happens but it's real quiet when I'm driving but when I push the clutch in to switch gears it gets louder til I disengage. Now it's getting to where it's steady and doesn't get louder nor softer. Is it the clutch going out possibly?
Old Sep 5, 2016 | 07:20 PM
frankie_b_jr's Avatar
frankie_b_jr
Sounds like the throw out bearing in going out. If you go into it that far plan on changing the clutch as well. It's a pain to pull it all apart and reassemble, then have to pull it apart again because of something else going out.
Old Sep 5, 2016 | 07:33 PM
morgancal's Avatar
morgancal
throwout bearing......buy the whole kit...like frankie says the next weakest link will go next...good luck
Old Sep 5, 2016 | 09:16 PM
Spillage's Avatar
Spillage
Once they start making noise, they don't have many miles left in 'em.
Take care of it sooner than later, or you'll be driving crash-box to get home.
Old Sep 7, 2016 | 08:07 AM
David Clauder
Preciate it guys. I'll let y'all know how it goes
Old Sep 7, 2016 | 04:07 PM
David Clauder
I took it to a shop to diagnose it and it's the throw out bearings and it was recommended to replace clutch kit too. Now I just gotta find some videos for replacing em since I have a transfer case and can't afford the labor fees
Old Sep 7, 2016 | 09:27 PM
Got a trans jack? Not really that bad of a job. Parts are just HEAVY.
