mpg drop
Old Sep 6, 2016 | 07:32 PM
Scatpack01's Avatar
Scatpack01
Default mpg drop
96 Ram 5.9 I changed the water pump, radiator thermostat, hoses.....fuel mileage dropped from around 15 to 10-12. Any idea what caused it? No codes showing so not sure if coolant sensor came unplugged. But that would show a code right?
Old Sep 6, 2016 | 08:13 PM
Not necessarily....... The one you are interested in is cleverly concealed down by the thermostat housing. You know, behind/under the a/c compressor. (sorry man)
Check and make sure it is plugged in good.
Welcome to DF!
Old Sep 6, 2016 | 08:29 PM
Scatpack01's Avatar
Scatpack01
well we forgot the small bypass hose and the hose to the thermo stat is leaking a little so we are gonna check on that.
